engine swap
Old Jun 11, 2017 | 08:24 AM
meahsdaddy's Avatar
Default engine swap
My wife has a 01 300m that the engine got hot. It still cranks and runs but after a few minutes it starts to rev up and down then dies . when it is reved up some it has a hard rattle almost knock in it now . i believe it needs a new engine . i have found a 07 3.5 with around 5000 miles on it that i can get very cheap .Will it work in it
Old Jun 11, 2017 | 08:26 PM
FIREM's Avatar
NOPE totally different engine configuration, only thing the same is the 3.5 liter displacement.
99-01 "LH" engine plug and play drop in. 02-04 can do but need swap flywheel, cam gear, engine harness and more.
SEE : What to do now!? - Page 2 - Chrysler 300M Enthusiasts Club
Old Jun 20, 2017 | 10:27 AM
meahsdaddy's Avatar
so a 07 3.5 will not work at all Not real sure of the year of the motor any way to tell
Old Jun 20, 2017 | 10:36 PM
the vin that came with the engine will be able to tell u what year it is.
Old Jun 21, 2017 | 01:38 PM
meahsdaddy's Avatar
where do i need to go to check it at .I haven't been able to find anywhere on line tom do Chrysler engines
Old Jun 21, 2017 | 09:17 PM
FIREM's Avatar
Engine Identification numbers are on the rear of the left bank block, just below the head deck. (drivers side)
The row of numbers that has a "T" in it is where to look, the first digit is the last number of the block year, followed by the "T", which is the casting plant, Trenton.
Next 5 digits tell if it is 3.2 or 3.5 and car it is/was in, next 4 are the month day of build. last 5 are the engine serial number.
Engine serial number usually does NOT match the VIN but at least you can tell year and date built, should be close to body date code on drivers door
Old Jun 22, 2017 | 07:03 AM
meahsdaddy's Avatar
thanks ill check it out
Old Jul 7, 2017 | 12:09 PM
meahsdaddy's Avatar
am i correct that this would be a 2000 model 0T35PC01402
Old Jul 7, 2017 | 09:13 PM
is this for the 07 engine or the one in your 300 now?
Old Jul 8, 2017 | 05:55 AM
FIREM's Avatar
Could be......the number provided is incomplete yet the first digit indicates 2000 (or 2010)
