Little or no heat
Old Dec 27, 2012 | 12:00 PM
Jbray59's Avatar
Default Little or no heat
A little help if possible. I have a 2000 Chrysler LHS that is putting out very little heat even if the climate control is set on high. In the last 10 months the heater core, water pump and head gasket have been replaced. Blower motor is fine and works on all speeds and you can change the temp settings on the climate control but no change in the temperature unless you set it to low and then it is all cool/cold air obviously. Any thoughts? THank you.
Old Dec 27, 2012 | 12:22 PM
Jbray59's Avatar
I should add that it doesn't matter whether the C.C. is on auto or manual. There is still very little heat blowing out.
Old Dec 27, 2012 | 12:29 PM
Jbray59's Avatar
THe thermostat has been replaced as well.
Old Dec 27, 2012 | 01:34 PM
possible BCM or blend air door motor
Old Dec 28, 2012 | 11:53 AM
Jbray59's Avatar
BCM? Thanks for your reply too.
Old Dec 28, 2012 | 11:59 AM
Jbray59's Avatar
BCM. BLower Control Module?
Old Dec 28, 2012 | 02:42 PM
Body computer
Old Dec 30, 2012 | 12:45 PM
Jbray59's Avatar
Well I did what one manual said to do as far as checking the ATC and came up with a code 36 which says "ATC Conrol communication failure" Honestly though that does not tell me anything. Does that mean the control itself or something else?
Old Dec 30, 2012 | 06:08 PM
Jbray59's Avatar
I did go and try replacing the head unit. Tried 3 different ones with the reult bing the same with a code 36. No other codes showed up.
Old Dec 31, 2012 | 02:18 AM
wire issue or BCM then
Jbray59
9
May 16, 2014 11:00 AM
reyesraiders1
Nov 11, 2010 09:39 PM
davet
Dec 19, 2007 04:18 PM
Screamineagle66
Mar 13, 2007 02:42 AM
ramfan5.9
Apr 29, 2005 11:25 PM
