no more stumbling, no more dying, 99 LHS
Old Aug 19, 2008 | 03:47 PM
DaveC8656's Avatar
Default no more stumbling, no more dying, 99 LHS
[sm=groupwave.gif]After digging thru the Haynes manual, I checked and cleaned the idle air control valve (IAC valve) and the throttle body with spray carb cleaner and the problem is solved. I removed the throttle body as a unit for a more complete cleaning and the car runs great, starts easier and idles smoother. Amazing. I think I can close the book on this one now. Hope this helps someone else. Blessings, DaveC.
Old Aug 20, 2008 | 07:11 PM
Iwant2playNOW's Avatar
Default RE: no more stumbling, no more dying, 99 LHS
where is this located? near the air filter?
Old Aug 26, 2008 | 12:18 PM
DaveC8656's Avatar
to Iwant2playnow, it is at the rear of the intake manifold, back under the sill plate that is just below the wipers. It needs to be remove in order to gain access to the throttle plate and IAC valve. Not difficult, just a lot of small fasteners and if I remember right, I had to park the wipers in the up position to get to one or two of them. To do that, turn the wipers on and then remove the wiper relay inside the power box under the hood at the LH side. Otherwise the wipers will simply park whenthe key is turned off. Hope this helps, blessings, DaveC.
v1rott
Mar 23, 2017 03:45 PM
ndw13
Sep 30, 2008 05:57 PM
DaveC8656
Jul 27, 2008 04:35 PM
rwatson03
Feb 16, 2008 05:41 PM
jlmills
Jul 25, 2007 08:32 AM
