Resovoir overheating but engine temp is normal need help???
Old Sep 29, 2007 | 07:03 PM
Krazy302's Avatar
Default Resovoir overheating but engine temp is normal need help???
I have an 1997 LHS and the engine has been running fine, I have had this car 4 months now it has 70,000 miles on it and all summer long never had a problem even with a/c on. Now when I idle for long periods of time or sit in traffic the resovoir seems to overheat but the engine temp gauge is not even 1/2 way up.. I changed the thermostat, and the temp sensor, I checked fan fuses and relays all are ok, the fans work they do come on. Don't know what to do next. I am gonna get a new radiator cap and try this.. Anyone have this happen to there 3.5 liter motor.. please help..[sm=wtf.gif][sm=wtf.gif][sm=wtf.gif][sm=WTFsgign.gif]
Well I changed the cap still the same thing.. And I don't ssee any oil in coolant or vis/versa..There is no bubbles in resevoir when running, and there is no movement of coolant in there either, the only time there was any movement is when I raised the idle to any rpm after 1400 then I could see some flow.. Maybe water pump fins are bad???? and no coolant is getting circulated around, that's why it's only overheating in the resevoir..
Old Oct 1, 2007 | 06:21 PM
ace's Avatar
ace
Default RE: Resovoir overheating but engine temp is normal need help???
Did you bleed the air out when you changed the t-stat i am not sure but i think their is a bleeder valve on the housing(not positive) If their is an air pocket your not gonna get flow
Old Oct 1, 2007 | 06:40 PM
Krazy302's Avatar
yes I bleed the system doesn't seem to have any air in it.. I am gonna change the water pump and timing belt, the car has 70000 miles on it and they reccomend changing belt at 100000 so I am just gonna do it a bit earlier.. and while I have it apart I got a new radiator for 60.00 so I am gonna replace that also, can't hurt, and at least if it's not the water pump and it's the radiator I don't have to take it out again..I will let you guys know how it goes, I am gonna do it tommarow at work..
300M Chic
12
Aug 4, 2020 07:36 PM
Denis.V
Sep 4, 2012 08:26 PM
allenw62
Mar 19, 2012 06:17 PM
tycho
Jan 1, 2011 07:27 AM
ymitchell7
Dec 22, 2010 10:34 AM
