Transmission issues
Old May 13, 2007 | 09:33 AM
ranger88den's Avatar
Default Transmission issues
My sister's '99 Concorde check engine light came on and she noticed a little difference in shifting. I checked the PCM with anActron scanner an received the following codes:
1st = P0733
2nd = P0715
3rd = P0700
4th = P0700
Does anyone know what might cause this or has had the same codes and know a fix. She has limited funds so if I can fix it for her and foregothe dealer it would be a good thing. The car has been well maintained w/61,000 mi..
Thank you for all suggestions and experiences, Dave
Old May 15, 2007 | 06:14 PM
Default RE: Transmission issues
P0733-GEAR RATIO ERROR IN 3RD
P0715-INPUT SENSOR ERROR
P0700-INTERNAL TRANS CONTROLLER
sounds like speed sensors to me replace both input and output 30 bucks each they are outside of teh tranny and screw in.
Old May 16, 2007 | 02:24 PM
Thanks for the advice. I only replaced the input sensor but that seemed to do the trick. Dave
Old Jun 22, 2007 | 07:41 AM
Bielskia's Avatar
Default RE: Transmission issues Please HELP fast.
I currently have a 97 Chrysler LHS. The transmission went into limp-n mode and threw codes 56, 57 and 28. I changed both input and output sensors and still get codes 56 57. After installing a new MVLPS I now get a code 24 and 28. The shift lever also moves out of Park w/o pressing the brake pedal.
I double checked all ground points and they are good.
What's next? TCM?
Any ideas please let me know.
Old Jun 22, 2007 | 09:05 AM
sorry i dont know what the codes u gave are i need p codes or chrysler codes
privat12
Jul 14, 2013 01:05 AM
german
9
Jul 2, 2011 04:28 PM
sexpot69
Jun 23, 2008 11:12 AM
luu5
12
Mar 13, 2008 10:42 AM
Tomguy
Jan 1, 2007 01:46 PM
