Transmission Oil Pan Troubles
Old Oct 20, 2012 | 04:10 PM
ollerich29's Avatar
Default Transmission Oil Pan Troubles
I have a '99 300M and have for a little over 3 yrs. I went to change the atf, and found one bolt missing, and in its place was some sort of sealant. After I removed the rest of the bolts I had noticed that the previous owners, or mechanic, had used this sealant on the whole pan and I cannot get the pan off to drain the fluid, and it needs it. Does anyone have any ideas on how to safely remove it? Thanks for any help.
Old Oct 20, 2012 | 08:56 PM
RTV is the recommended gasket for Chrysler cars with a 42RLE trans
U leave 2 bolts in on the side unscrewed a little and then use a hammer and smack the side of the pan it will loosen up and fall down.
RT469
Feb 3, 2012 10:34 AM
gato_solo
Jun 23, 2011 06:31 PM
MauriS69
Mar 17, 2009 10:31 PM
Jonieshilo
Jan 27, 2008 01:15 PM
JimboXL
Feb 22, 2007 12:44 AM
