Trouble codes
Old Sep 20, 2007 | 12:12 AM
bdevil's Avatar
Default Trouble codes
Hey there all, I am having issues with my 2002 300m special 3.5 HO v6, 65000 miles.I scanned the car for codes and I received the following P0700, P0731, P0781, P1776, P0841, and again P0700 it said I had six trouble codes and the P0700 came out twice. Can anyone tell me what these codes mean and what parts I need to replaced and/or fix. I would rather not take it to the dealer since I had them repair these problems and they said they could not duplicate the problems I stated but they did replace an o2 sensor and claimed that was the problem but I had the CEL come back onduring my trip back home from the dealer.
P0700-Trans control sys malf.
P0731-Gear 1 ratio incorrect
P0871-Trans fluid sensor/switch CCKT range/perf.
P1776-Mnufacturer controlled transmission
P0841-Trans fluid sensor/switch A CKT range/perf.
Thanks for your help guys...
Old Sep 20, 2007 | 09:10 PM
WYOCHIMNEYSWEEP's Avatar
Default RE: Trouble codes
possible bad ground at trans ecm?
Old Sep 20, 2007 | 10:50 PM
P1776-SOLENOID SWITCH VALVE LATCHED IN LR POSITION
P0871-OD PRESSURE SWITCH SENSE CIRCUIT
P0841-LR PRESSURE SWITCH SENSE CIRCUIT
possible causes
RELATED DTC P0841 PRESENT
INTERMITTENT OPERATION
TRANSMISSION CONTROL RELAY OUTPUT CIRCUIT OPEN
L/R PRESSURE SWITCH SENSE CIRCUIT OPEN
L/R PRESSURE SWITCH SENSE CIRCUIT SHORT TO GROUND
L/R PRESSURE SWITCH SENSE CIRCUIT SHORT TO VOLTAGE
INTERNAL TRANSMISSION PROBLEM - SSV STUCK
PCM - L/R PRESSURE SWITCH SENSE CIRCUIT
Old Sep 21, 2007 | 10:04 AM
bdevil's Avatar
thanks for the info but it's all mumbo jumbo to me since I don't know what it all means. Do you know of the parts and/or the steps I need to take to resolve these issues. Greatly appreciated...
Old Sep 21, 2007 | 11:07 AM
u wont be able to do any of the above if u dont know what i just named. U should take it in. Besides it not alwase a part that is bad tranny computer and or wire issue.
Old Sep 21, 2007 | 11:24 AM
bdevil's Avatar
sound good, thanks...
Jfizzle
Feb 22, 2020 04:37 PM
paddy159
Oct 11, 2012 02:27 PM
scottshaw
Aug 23, 2011 04:52 PM
Qckslvr
Jan 22, 2011 06:11 PM
valkyr
Sep 19, 2009 10:41 AM
