Can I retrieve trouble codes without a scanner?
Old Jan 16, 2011 | 04:56 PM
Qckslvr's Avatar
Default Can I retrieve trouble codes without a scanner?
My '98 Sebring conv. lit the "Service Engine Soon" indicator yesterday, and I can't find anything wrong, or clear it. Is there a way to retrieve the trouble codes without the use of a scanner? I tried the "on-off-on-off-on" trick, but that doesn't seem to work on this vehicle. Any ideas? Thanks.
Old Jan 16, 2011 | 09:48 PM
Take it to Autozone. In most states they'll read the codes for you for free.
Old Jan 19, 2011 | 05:49 AM
jonthee's Avatar
Try the key-dance-method 3-5 times, then maybe it will work
Old Jan 20, 2011 | 07:47 AM
Qckslvr's Avatar
Talking Trouble cleared - try this if you ever encounter it
Thanks for the advice, friends. I'll try the 3-5X key dance trick for the future but, believe it or not I was able to clear the "Service Engine Soon" light by simply removing the gas cap for a few seconds, cracking open the anti-spill flapper in the fuel filler tube, and then replacing the gas cap.
This car lives in the garage in Florida for months at a time, and whenever I leave, I always fill the tank to eliminate the potential for corrosion. Although it didn't throw the light for a few days after I returned, I suppose fuel expansion caused something in the emissions system to read out of tolerance, and gave me the light. For now, at least, problem solved!
Old Jan 20, 2011 | 12:12 PM
Could be that the gas cap wasn't on tight. It's supposed to be on tight to prevent vapor leakage from the tank. If it's not on tight, the system leaks and you get a P0455 code.
Old Jan 22, 2011 | 06:11 PM
Qckslvr's Avatar
The cap was definitely on tight. I use a locking cap on that car, and it was secure when I removed it. I've gone through at least twenty start cycles since then, and it is still clear, so I suppose it got happy. Go figure.
Thanks for the advice.
Jfizzle
Feb 22, 2020 04:37 PM
jvh24521
Sep 6, 2012 07:02 AM
SpudlerT+CTouring
Oct 19, 2011 01:01 PM
dupek1974
Oct 7, 2009 12:16 PM
