Old Dec 19, 2019 | 06:02 PM
  #531
Originally Posted by Halfdime300
I need a code for this radio
These T17AH radio codes cannot be calculated but have to be looked up on the Chrysler Dealer database
This means that the code may not be available for free from anywhere on the Internet.... but you could try asking your local Chrysler dealer
Otherwise try emailing
restoredclassic@aol.com
Mention this Forum
Old Dec 20, 2019 | 12:10 AM
  #532
Grease's Avatar
Can anyone help with the radio code?
The local Chrysler office couldn't beat it.
Gave a code that is not valid.
Vin: 2A8HR64X08R833990
Series T00BE092851339
Model P05064400AJ
I'll put in some pictures, maybe it'll help.
Thanking Janek
Old Dec 20, 2019 | 04:37 AM
  #533
Model P05064400AJ
Thanking Janek
T00BE092851339 try code 6859
Old Dec 20, 2019 | 06:32 AM
  #534
Grease's Avatar
That's the code 6859 was given to me by the local Chrysler office.
But it doesn't fit, the radio doesn't embrace it
Old Dec 20, 2019 | 06:54 AM
  #535
Grease's Avatar
4-5 times I entered code 6859 and on the radio came this letter:
Old Dec 20, 2019 | 08:38 AM
  #536
6859 is definitely the original code for this unit when it left the factory.
Have you tried it when fitted into to your car?
Is it the original radio fitted in your car since new?
If YES then try code 0000 ONCE ONLY
If not try code 1234 ONCE ONLY
If neither work then your unit has most likely been decoded/recoded in the past to a new number.
This means it will have to be taken into a Radio Decoding Workshop to decoded/recoded again
Post back here with any results.
Old Dec 20, 2019 | 12:26 PM
  #537
jms100's Avatar
Default PO5091117AC S/N T11AH.. No Code required
Originally Posted by jms100
Amilo, thanks for quick response. I'll post here with the resolution should I find one.
John S.
This model and serial number did not ask for code when installed. Radio was out of a 2010 vehicle and I suspect that is the reason why.
Others with this model and serial number sequence may not need a code entered. TBD
John S.
Old Dec 20, 2019 | 12:58 PM
  #538
DivineSr's Avatar
Default Radio unlock code
[QUOTE=Edmon Rangelov;93279]Code 3453[/SN
SN: T16QN109212230
vin. 1C3CCBBB0CN275815
Chrysler 200 2012
Old Dec 20, 2019 | 01:06 PM
  #539
John S.
A couple of points:-
Are you are sure that this particular model is compatible with fitting it into your different vehicle?
Also I believe that many models have the choice of being VIN coded.
If the VIN has already been loaded into the radio then no code is required.
But if no VIN has been loaded, then the correct radio code will have to be entered every time the battery is disconnected.
It looks as though you may have to take it into a Radio Decoding Workshop to be fixed
Old Dec 20, 2019 | 01:12 PM
  #540
Originally Posted by DivineSr
SN: T16QN109212230
Chrysler 200 2012
These T16QN radio codes cannot be calculated but have to be looked up on the Chrysler Dealer database
Otherwise , if you are in a rush , try emailing
Mention this Forum
