02 with the 2.7 has rusted and pitted cams
Old Mar 13, 2014 | 07:35 PM
procraneop's Avatar
Default 02 with the 2.7 has rusted and pitted cams
The used Motor Got Condensation In It And After Taking The Top Off I Noticed The Cam Shafts Are Pitted And Rusty...If I Simply CleanThem Up But After I Do There Still Is Pits On The Lobes Will That Be Ok?
Old Mar 14, 2014 | 11:09 AM
Depends on how bad they are. Chances are the cylinder walls and/or piston rings are rusty too. That could affect compression. This all might be a sign of a bad waterpump. How is the oil in the crankcase? Is there any indication of coolant in there? Might want to take this one back. You want an engine as close to your vehicle's production date as you can find. There was a change in the engine around 2004 (?) that makes the newer engines incompatible with your engine computer.
Old Mar 17, 2014 | 06:00 AM
procraneop's Avatar
Thanks DC...
I Cleaned Everything Up ...Lobes Are Better Not Perfect But Cylinders Look Good...installed New Water Pump And Timing Chain...Motor Is The Same year...
Thanks For The Insight
Old Mar 17, 2014 | 08:44 PM
Take some pictures of your project and post them up in an album. Keep us posted.
AlanC
15
Aug 12, 2014 01:12 PM
96jxitommy
Dec 22, 2011 11:17 AM
jtrent
Mar 5, 2008 12:07 AM
jerryls
Oct 1, 2007 06:13 PM
Imperial90
Jan 19, 2006 12:01 PM
