02 Fusible link location
Old Feb 17, 2010 | 03:54 PM
zerko's Avatar
Default 02 Fusible link location
I am looking for any possible fusible link locations for an 02 Sebring Sedan with a 2.7L engine.
A wire diagram I have shows that there is one located between the alternator and the Positive boost point in the engine compartment. I want to know exactly where it is, so I don't have to hack-apart all the harness.
Thanks, Adam
Old Feb 17, 2010 | 09:49 PM
right near the battery it will be green in color going to the red + cable
Old Feb 17, 2010 | 09:56 PM
There should be one in a dark green 10 gauge wire leading from the alternator to the starter motor. If it's blown, you may be able to find it by feeling the wire. If you come to a point where there's a detectable gap under the insulation, you've found it.
Old Feb 18, 2010 | 10:25 PM
zerko's Avatar
Cool! I will look for that tomorrow.
Thanks!
Old Nov 14, 2012 | 04:58 AM
heathric's Avatar
Default still broken after 2 years?
Zerko, did you ever get your car fixed? Part of forum participation is contributing by posting a solution. Otherwise, forums are pointless.
Old Nov 15, 2012 | 07:12 PM
zerko's Avatar
I did get it fixed. Used a test wire between alternator and battery post, started charging right away. Wire rotted off at starter connection.
Sorry my partisipation is not up to speed.
Old May 13, 2014 | 12:49 PM
LFC6814's Avatar
I have a 2001 sebring 4 door LX, 2.7, the wire from alternator is red, can't see on top of starter, it's hidden by front motor mount, is that where the fusible link is? If so why would they put it their?
shnormo
May 8, 2011 08:33 PM
manh
Jan 13, 2011 03:23 PM
joeuc23
Oct 15, 2008 05:30 PM
Dec 15, 2006 01:47 PM
ramfan5.9
Apr 30, 2005 05:41 PM
