02 sebring auto transmission issues 2.7 engine
Old Apr 15, 2008 | 05:29 PM
rdmotti's Avatar
Default 02 sebring auto transmission issues 2.7 engine
Hi folks, am new at this and hoping for some info to my problem. Had a transmission service done with kit by Mr Lube and now the transmission downshifts very abruptly. Have an 02 sebring with auto trans and 2.7 engine with 85000 kms. The fluid was changed by Mr Lube three months ago without any broblems to the shifting whatsoever. Any feedback of any kind would be greatly appreciated.
Old Apr 15, 2008 | 08:28 PM
moe's Avatar
moe
Default RE: 02 sebring auto transmission issues 2.7 engine
try disconnecting battery for a couple minutes. reconnect,then start and double check your fluid level.hopefully it will re-learn.keep me posted moe
Old Apr 15, 2008 | 11:07 PM
rdmotti's Avatar
Hi Moe, I'll give that a try and keep you posted. Many thanks for the feedback.
Cheers,
Ron
Old Apr 17, 2008 | 03:07 AM
rdmotti's Avatar
Hi Moe, disconnected battery terminals in engine compartment for several minutes as advised and reconnected. Transmission fluid is fully topped up. Took the car for a spin and unfortunately no change to the abrupt downshift.
Thanks for your time.
Cheers,
Ron
Old Apr 17, 2008 | 03:25 PM
moe's Avatar
moe
might have to take it back for what they call a quick learn on the trans.is the check engine light on?
Old Apr 18, 2008 | 12:32 AM
rdmotti's Avatar
Hi Moe, no, the check engine light is not on! Shall I take it back to the dealer for a trans quick learn? What does the procedure entail?
Am I looking at big bucks? Am not so sure I trust the Chrysler dealer I take the car to in light that they always find something to fix, find them very pushy!
Cheers,
Ron
Old Apr 18, 2008 | 08:13 AM
moe's Avatar
moe
alot of dealers are like that ron. it involves using the scan tool (drb) to reset the trans,called quick learn.takes like 10 mins.one good trick is to tell the dealer your thinking about trading the car next week.not sure what make your looking for.works every time.!!! moe
Old Apr 18, 2008 | 02:45 PM
rdmotti's Avatar
Thanks Moe, you've been a huge help. I'll try that next week with the dealer and see how it 'll pan out. I'll also keep you posted on the end result of the trans quick learn.
Cheers,
Ron
Old May 3, 2008 | 03:18 PM
rdmotti's Avatar
Hi Moe, took the sebring to the dealer for a quick learn, and yes, the tranny now downshifts flawlessly! Thanks again for your help in this. Dealer charged me $100 for the procedure. Does this mean another quicklearn when the next tranny flush and filter change is performed? Why does this happen?
Thanks,
Ron
german
9
Jul 2, 2011 04:28 PM
farmerbob02
Apr 13, 2011 12:04 AM
gpatel
Nov 4, 2010 04:34 PM
Bobby721
Nov 19, 2008 08:21 AM
rdmotti
Apr 18, 2008 02:45 PM
