02 Sebring convertible - add ABS
Old Sep 18, 2012 | 02:05 PM
chris_kucia's Avatar
Default 02 Sebring convertible - add ABS
Have an 02 Sebring GTC convertible without ABS.
Local Pull-A-Part has an 02 Sebring convertible with essentially the same options as mine, but it has ABS.
If I were to obtain all the sensors, harnesses, the ABS unit/module and the cluster from the donor and install it in mine, would the ABS system be recognized and would it operate correctly?
I searched the FSM and couldn't find anything about swapping ABS modules and needing to reprogram them, but that doesn't necessarily mean that the module would be recognized if it suddenly showed up - I presume the BCM is going to need to see it, and, if it does, it's going to complain in the future if it disappears.
I'm confident I can get all the pieces installed and in place, but I'm not so confident it will work after I do.
Anyone know?
jimmy154
Dec 14, 2019 09:45 PM
tylersheehy
Jun 18, 2013 03:47 PM
myxfire
Jun 23, 2005 02:59 PM
myxfire
May 5, 2005 10:49 AM
