03 sebring Coolant leak
Old Nov 3, 2017 | 12:23 PM
AdamLag's Avatar
Default 03 sebring Coolant leak
2003 Sebring 2.4L DOHC 170k
I have a coolant leak that is spraying somewhere up at the top. I haven't really looked to find the issue. I am looking to see if there happens to be any common problems along these lines. Car doesn't get hot. Heat doesn't blow hot unless im moving, But i assume that is because of low coolant. If anyone has an idea i would love to hear them
!! Thank you!
Old Nov 3, 2017 | 10:59 PM
Here's an idea. Look at it carefully when it's leaking and see where the leak is coming from. You should see steam or bubbles or coolant leaking out. Then replace the leaking part.
It's a bad idea to drive around leaking coolant. An overheated engine can seize up and leave you stranded with some very expensive repair bills.
JaxJim
Nov 22, 2015 12:16 PM
teddysmith1952
Dec 16, 2011 08:31 PM
neh218
64
Nov 28, 2011 03:54 PM
z131
Feb 10, 2011 11:05 AM
jimG
Sep 8, 2010 12:26 PM
