'04 Sebring Conv. 2.7L V6 P303 Code
Old Mar 24, 2010 | 01:09 PM
Taz,
It might help if you understand that the way these things work is that they have a constant voltage supplied to them. The computer connects them to ground to complete the circuit at the exact time it wants them to work. That's what is meant by a "ground pulse".
Old Mar 24, 2010 | 04:19 PM
taz's Avatar
taz
thanks dcotter,
normally someone says to check for ground I use ohm meter to check to verify it's grounded, check for power use voltmeter to see if there is x volts present.
guess that's the difference in working on cars everyday and occasionally, you know when someone says to check for ground on injector or coil they mean ground pulse.
i have some wiring diagrams and will try checking for power and ground pulse tonight.
thanks to both of you for help so far.
Old Mar 24, 2010 | 09:12 PM
taz's Avatar
taz
ok, so I checked and both and getting power and ground pulse on both. noticable difference in engine with either unplugged also.
Old Mar 29, 2010 | 10:24 AM
taz's Avatar
taz
bump..
Old Mar 29, 2010 | 01:32 PM
  #15
so the fuel injector and coil both have good power and getting the ground signal correct?
Now its time the check the plugs and internal engine run a compression test on #3
Old Mar 29, 2010 | 01:43 PM
  #16
taz's Avatar
taz
yes, on both one wire was always hot with engine running, the other wire was getting ground pulse.
ok. I will try a compression test and check the plugs again
marcpilot1
Jan 12, 2014 10:03 AM
cyrone
Mar 24, 2011 11:39 PM
aifam55
Jan 22, 2011 05:49 PM
edbobfamily
Sep 25, 2008 10:20 PM
