04 Sebring Sedan 4cyl - Front Rotor Replacement
Old Apr 29, 2012 | 09:48 AM
ManuteSwol's Avatar
Default 04 Sebring Sedan 4cyl - Front Rotor Replacement
How many bolts NEED to come out to get the caliper off the rotor and what size are they? It looks like two 18mm mounting bolts to me. Can anyone verify ?
Old Apr 29, 2012 | 11:28 AM
TNtech's Avatar
18 or 21, I cant remember right off hand. Yes, the two large bolts. If you are putting new rotors on, you'll need to compress the caliper piston some to make room before you put them back on.
Old Apr 29, 2012 | 11:29 AM
AnthemBassMan's Avatar
From: T-County, Ohio. Good ol' farm country! Or at least what's left of it...
-It's held on with two caliper slide bolts. Sorry, but I haven't changed the pads on mine yet, so I can't help you with the bolt size.
L8R,
Matt
Old Apr 29, 2012 | 12:10 PM
TNtech's Avatar
L8R,
Matt
There is a caliper mount he's talking about. You can take the whole mass off with the two large bolts on the back side. If you just take the caliper off, the rotor is still trapped by the mount. The caliper slide bolts are either 10 or 13MM. I can never remember, they always change stuff...lol.
Old Apr 29, 2012 | 01:55 PM
ManuteSwol's Avatar
Thanks guys. Quick question, is there any way to confirm these bolt sizes? I have various manuals but no dice..
Long story short, I had the tire off.. realized I didn't have the wrench I needed -- got pissed, put the tire on.. without jotting down the believed size. I'm THINKING 18... but can anyone confirm? I'm pretty sure it's not as large as a 21. Fairly certain I tried a 19 and it was too large, while a 17 was too small --- but the frustration can F with your memory
Old Apr 29, 2012 | 03:51 PM
TNtech's Avatar
Originally Posted by TNtech
18 or 21
Old Apr 29, 2012 | 07:17 PM
ManuteSwol's Avatar
You narrowed it down to two... but surely it is one or the other
I do not have either wrench..
Old Apr 29, 2012 | 07:30 PM
-Well that bites! I never had a car where I had to remove another bracket after removing the caliper just to get the rotor off. Oh well. I guess I'll cross that bridge when I get to it...
L8R,
Matt
Old May 13, 2012 | 03:08 PM
ManuteSwol's Avatar
They WERE 18mm bolts. Bought an 18mm wrench and a 21mm socket. Once the socket I arrived, I knew it was too large.
Anthem, I think you are misunderstanding.. lol. Two bolts removes the caliper FROM the bracket that it mounts to, thus freeing up the rotor. I suppose you could replace the pads while you have the caliper off, though it'd be more of a pain.
Old May 13, 2012 | 03:31 PM
If I recall that job, you need an oddball size Allen wrench on the caliper slide pins. It was something like 7mm. Every allen wrench set sold has 6mm and 8mm but not 7mm. I bought a 7mm size that comes in a socket you can use with a 3/8ths ratchet.
I guess you can do it without removing the slide pins but the better way is to pull them and use a little high-temperature grease on them when putting it back together.
