12 200 2.4 no crank at all when turning key
Hello,
have. 12 200 that won’t crank at all when turning the key. I can make the starter but putting power to it. I also have replaced the TIPM with a used one. What else can I look at why it won’t crank.
thanks to
thanks to
I replaced TIPM since i thought the issue was there for the no crank issue, I get a red dot blinks then it goes away on its own
Very likely there are active and stored diagnostic codes in the some of the control modules, the WCM (WIN Control Module) being one of them. These are not emissions related codes so they will not set the CEL (check engine lamp) and may show up as body codes ('C' prefix). Reading these codes will assist in determining the nature of the issues.
A number of handheld scanners are able to access all of the 12+ control modules in the vehicle. There are also 2 software apps that I am aware of, alphaOBD and appcar-diagFCA, that are able to read these control modules.
