12 200 2.4 no crank at all when turning key
Old May 10, 2024 | 04:10 PM
ramirez32385's Avatar
Default 12 200 2.4 no crank at all when turning key
Hello,
have. 12 200 that won’t crank at all when turning the key. I can make the starter but putting power to it. I also have replaced the TIPM with a used one. What else can I look at why it won’t crank.
thanks to
Old May 10, 2024 | 07:52 PM
anti theft will disable it
Old May 10, 2024 | 08:30 PM
Will the key have to be replaced?
Old May 11, 2024 | 08:51 AM
ggoose's Avatar
Was the TIPM replaced before or after the no crank issue? Why was the TIPM replaced?
Is the red security dot lit in the instrument cluster?
Old May 11, 2024 | 10:21 AM
I replaced TIPM since i thought the issue was there for the no crank issue, I get a red dot blinks then it goes away on its own
Old May 11, 2024 | 02:40 PM
Could the issue be the WIN module?
Old May 13, 2024 | 07:46 AM
ggoose's Avatar
Very likely there are active and stored diagnostic codes in the some of the control modules, the WCM (WIN Control Module) being one of them. These are not emissions related codes so they will not set the CEL (check engine lamp) and may show up as body codes ('C' prefix). Reading these codes will assist in determining the nature of the issues.
A number of handheld scanners are able to access all of the 12+ control modules in the vehicle. There are also 2 software apps that I am aware of, alphaOBD and appcar-diagFCA, that are able to read these control modules.
Old May 13, 2024 | 07:59 PM
How is the WIN or WCM get programmed?
Old May 14, 2024 | 11:32 AM
From a dealer that has the software to install the vin and pin number
Old May 21, 2024 | 06:08 PM
Now I get a code U0141, what is the fix? According to my code it has to do with the communication with the TIPM, what can I look for?
