1998 sebring no ground to starter relay in crank
Old Dec 28, 2023 | 12:33 PM
Michaelraynor57's Avatar
Default 1998 sebring no ground to starter relay in crank
Old Dec 28, 2023 | 01:14 PM
ggoose's Avatar
er - what ?
Not understanding the issue. Please explain the issue in more detail. What happens when you try to start the engine?
Old Dec 29, 2023 | 09:07 AM
Default No ground to starter relay
Turn the key and nothing happens. Checked battery connections, batt.and charge are good.
Old Dec 29, 2023 | 09:09 AM
Car came in no crank no start. Abs pump blows the abs fuse.
Old Dec 29, 2023 | 02:35 PM
ggoose's Avatar
Does the radio work with key in ACC/RUN? If not, it is likely fuse #8, 20amp, under the hood.has popped. This is an indication the starter is failing and should be replaced. The ACC/RUN feed for the radio, etc share the same power feed/fuse that is used for the starter in the START position.
The abs fuse would not prevent the engine from cranking.
Old Dec 30, 2023 | 11:49 AM
ggoose's Avatar
There are 2 fuses for the abs module, fuse #15 - 40amp and fuse #22 - 20 amp. Which is blowing?
bjm4002
Sep 15, 2024 01:38 PM
e82moore
Sep 8, 2021 09:16 PM
jetman750
Mar 10, 2017 01:04 PM
2001sebring2point7
May 9, 2015 12:22 AM
pjaker104
Jan 9, 2011 07:32 PM
