2006 Chrysler Sebring 2.7L No Start...
Old Mar 9, 2017 | 08:05 AM
jetman750's Avatar
Angry 2006 Chrysler Sebring 2.7L No Start...
Morning, have a 2006 Sebring will not turn over checked power at starter wire at key switch ok found a blown fuse in engine fuse box replace and it cranked and Ran for a second (driver ran out of gas!!) then after 6-7 times turning over it would not crank checked power to starter ok but no crank single rechecked all fuses- ok? thinking its in the computer in front of fuse box????
thank you
Old Mar 9, 2017 | 10:30 AM
You have power to the starter but the starter will not crank.
Did it occur to you that the starter may be the problem?
Old Mar 9, 2017 | 11:11 AM
jetman750's Avatar
A lot of things occured to me but the starter is not one of them! I have NO power at the trigger wire from starter relay to the starter, back from the relay to the key every thing is fine....
Old Mar 9, 2017 | 12:24 PM
"checked power to starter ok but no crank"
So you didn't really mean that?
What you meant is that you have no problem with power getting TO the relay from the key, but no power is getting FROM the relay to the starter.
Did you consider there might be a problem AT the relay?
Old Mar 9, 2017 | 12:47 PM
jetman750's Avatar
Looks like its the PCM, I can jump at starter relay and it will crank. Thanks for your replys!
Old Mar 9, 2017 | 12:49 PM
jetman750's Avatar
also changed relays still same problem removed power dist box and checked wiring, all ok
Old Mar 10, 2017 | 01:04 PM
A faulty PCM will probably generate an error code telling you it has a problem. Before you replace the PCM, get a scanner on it and see if there are any codes.
If you do decide to replace it, look for replacement services on-line rather than buying a new one. You can expect to pay over a thousand for a new one and around $200 for a refurbished one.
Cometmom1
Jun 1, 2016 02:55 PM
mlo356
Jan 13, 2013 03:21 PM
Raindrop
Feb 22, 2011 05:47 AM
Butch
Sep 1, 2010 12:37 PM
bobnickell
Sep 16, 2009 09:51 PM
