1999 Sebring transmission problem
Hello.
My car runs fine most of the time however sometimes the check engine light will come on and then it will not shift. I can be in any gear and it will just stay in that gear until I stop and kill it which seems to reset it and it work fine. I will then drive for awhile and the check engine light goes off. It does it very sporadically and usually drives very good. I have had the codes checked when it was on and the codes are P034, p1776
When was the last time you changed the fluid in the transmission? Most transmission problems can be related directly or indirectly to the fluid. It should be changed every 60,000 miles or so. Use only the fluid that Chrysler recommends for your car.
Trouble code table: http://www.2carpros.com/kpages/diagn...uble_codes.htm
I changed the filter yesterday, and have a new input speed sensor to put it (just have to get a wrench big enough). I have driven it about 40 miles since changing the fluids and it hasn't done it again yet. I will drive it more today and let you know. thanks.
crazymanrols
May 5, 2013 04:35 AM
dmschuler
Jan 5, 2011 09:23 AM
shawnkh2003
Jun 14, 2007 04:22 PM
