2.7L engine swap!!! Help Please!!!!
Old Feb 19, 2008 | 11:54 AM
jell412's Avatar
Default 2.7L engine swap!!! Help Please!!!!
i jus bought a 2001 sebring sedan lxi with a blown engine.i was gonna get a new 2.7 but after some research and advise the 2.7 is the biggest piece of junk ever. has anyone put a 3.2/3.5 swap in? what all has to be changed? Please help me!!!!!
Old Feb 19, 2008 | 12:16 PM
rjasp2000's Avatar
Default RE: 2.7L engine swap!!! Help Please!!!!
Hi going through the same thing. I did some research as you can see in this forom under my ID and everyone says not to use a differant motor use another 2.7. I just found a 2.7 out of a 2004 sedan with 16000 miles on it. Not sure where you are from but here is a #800-649-9337 they have an 2004 2.7 36000 miles.I would have boughtthis if I didn't alreadyfind one. This motor I am telling you about is in Freetown Ma. Or go to www.car-parts.com and search your area. Russ
Old Feb 20, 2008 | 04:02 PM
powers84's Avatar
i wouldnt do that if i where you i got a 2004 engine in my 2001 and it wont work because of the computersare different. check my fourms. good luck
Old Jul 29, 2009 | 12:09 PM
Protos's Avatar
My first post:
Sorry to revive this old thread, but I just wanted to share my experience with other members and same them much money and time.
My wife has 01 Sebring that the engine blew up on her while I was away. I come back from my trip to find an 04 engine in it that will not start. The local mechanic gave up on it and the dealer took close to $600 to say they can't find what is wrong with it.
To make a long story short, If you want an 04 engine to run with existing 01 engine and tranny computers, this is what you have to do:
1. Use the flywheel from the 01 engine. 01 and 04 fly wheels have different slot patterns for the crank sensor.
2. Use the cam pulley fixed to the cam gear (bank close the bumper) from the 01. The pulley on the 04 engine have different slots for the cam sensor.
Note that step number two is very delicate as it requires messing with the timing chain as the pulley on some of these engines are riveted on to the gear and some are bolted. If you came across the riveted ones, you will have to take the whole gear out and pop the rivets, and you might mess the timing if you are not careful.
good luck with all of you guys.
Old Feb 15, 2017 | 09:53 AM
Shaun Hunnewell's Avatar
Default 2.7 to a 3.2
I have a 2007 Chrysler 300 with blown 2.7 I would like to swap it with the 3.2
my question is can it be done and what do I need to do.for the swap can I reuse the transmission and other parts .....please help is there a different year engine I can use
thook
Jan 20, 2024 01:28 PM
Massive_Dynamic
Sep 19, 2014 05:04 AM
sebringphanatic
Jul 25, 2009 12:03 AM
andbudzi
Feb 20, 2008 04:07 PM
GreenCar
Jan 12, 2006 03:00 PM
