2000 Chrysler Sebring Convertible Trans shift problem
Old Sep 25, 2012 | 01:48 PM
mta318's Avatar
Default 2000 Chrysler Sebring Convertible Trans shift problem
I just bought a 2000 Sebring Convertible with approx 130,000 miles. When I slow down it usually downshifts into first gear really hard. Sometimes it shifts ok into first, and every other gear it shifts to just fine. What causes this, and how difficult is it to fix it?
Old Sep 25, 2012 | 03:09 PM
When is the last time the transmission fluid was changed? No idea, right? Might want to start there.
Another possible source of trouble is the solenoid pack. Search the forum and the web for information about that. If you're handy and have some basic tools, you may be able to do it yourself.
Those are relatively inexpensive things that may help. If these things don't do the trick then you will need to get it in to a pro who has the equipment and knowledge to diagnose it properly. Be prepared to spend some money. If you bought a 13 year-old car with transmission issues, I assume you didn't pay much, so now the expensive part begins. Better to address the problem sooner rather than later as it won't get cheaper to repair with time.
Old Sep 25, 2012 | 04:47 PM
mta318's Avatar
I hadn't thought about the solenoid pack, but I did consider the fluid. I was also thinking either the input sensor in the trans could be bad based on what I had found elsewhere on the forum. I guess I should start with the fluid first then.
Thanks for your help
OV10dude
Cirrus & Breeze
Jul 23, 2012 04:36 PM
dblcruzin
Jun 24, 2010 10:13 PM
parlayjay
Apr 18, 2010 03:28 AM
jhuntsebring
Mar 1, 2009 10:33 PM
benr
Feb 25, 2007 03:44 PM
