2000 jxi no crank
Old Oct 25, 2020 | 10:20 PM
Fustamunge's Avatar
Default 2000 jxi no crank
Hello. New to the forum. My daughter pulled in the drive way and when ready to leave, the car would not crank. I tried to jump it thinking it was a weak or dead battery to no avail. Pushed it into the garage and charged the battery. Did not make a difference, Replaced the starter and still no crank. All the lights on the dash come on and I can hear a relay chatter but no crank. I have check the fuses and swapped several of the possible relays in the box under the hood and still nothing. When the key is turned I get 12v to the connector on the starter and I measured 12v at the starter as well. Not sure what to do next.
Old Oct 26, 2020 | 10:48 AM
Try cleaning every connection you can get to between the battery and the starter. Although you may have 12 volts there, a corroded connection may be able to pass voltage but not sufficient current to crank the starter.
Old Oct 26, 2020 | 05:46 PM
Fustamunge's Avatar
I re-cleaned the battery terminals (were still good as the battery is about 18mths old and I cleaned them well when I installed it. I also cleaned the main ground on the strut tower. The connections on the starter are new and I cleaned the main power cable there as well. I will look in the engine compartment for other ground locations to clean and give it a go. Thanks!
Old Oct 27, 2020 | 01:46 PM
ggoose's Avatar
Does the radio play? If not, check fuse #8 (20 amp) under the hood. A bad starter will pop the fuse which also powers the radio.
bjm4002
Sep 15, 2024 01:38 PM
Will.Ambo
Jun 20, 2023 01:26 PM
stloui024@yahoo.com
Aug 16, 2016 11:04 PM
2001sebring2point7
May 9, 2015 12:22 AM
p8ntballnxj
Feb 5, 2012 07:23 PM
