2000 Sebring vert JXI
Old May 19, 2008 | 10:53 AM
mybring2000's Avatar
Default 2000 Sebring vert JXI
I need a complete wiring diagram for my 2000 Sebring Convertible JXI.
Problems: 1. Radio no sound from speakers; 2. No power to convertible top (motor working). 3. Turn car on, after about 15 minutes turns off.
4. Engine oil light stays on until after started.
WhatI need desperately is a detailed layout of the wiring throughout the vehicle. I feel most importantly what I need is a detailed layout of the wiring path for the convert. top. Howexactly is it powered, what's connected to it, etc.? I need to see a clear path of determining how to make top go up and down.
Old May 20, 2008 | 12:47 AM
irdaneel's Avatar
Default RE: 2000 Sebring vert JXI
At the Autozone.com website they have what appears to be a complete set of wiring diagrams for your vehicle. (I only looked briefly) You must register to use, but it is free, and a valuable resource.
Do you get codes? MIL (check engine) on? If not, check the ASD relay (automatic shutdown) if your vehicle is equipped. The stalling after 15 min could also be your crankshaft sensor, or camshaft sensor (possibly integrated into the distributor if not separate). Heat does affect the operation of these items if they are faulty.
The oil light doesn't bother me, as it indicates a lack of oil pressure, and when the motor is not running, there is none.
Old May 20, 2008 | 11:55 AM
moe's Avatar
moe
Old May 20, 2008 | 11:56 AM
moe's Avatar
moe
Old May 20, 2008 | 11:57 AM
moe's Avatar
moe
whoops here you go.............
POWER TOP SWITCH - BLUE 6 WAY
CAV
CIRCUIT
FUNCTION
P6 20RD/WT
CONVERTIBLE TOP RELAY UP B(+)
Z1 20BK
GROUND
Z1 20BK
GROUND
P5 20YL/BK
CONVERTIBLE TOP DOWN RELAY B(+)
P118 20WT
POWER TOP INHIBIT RELAY OUTPUT...........
Old May 20, 2008 | 11:59 AM
moe's Avatar
moe
look how the power amp is that curcuit!!!
Old May 20, 2008 | 12:00 PM
moe's Avatar
moe
moe's Avatar
moe
that good?moe
Mr Pilkington
Oct 19, 2018 12:11 AM
richcod
Apr 6, 2012 07:54 PM
ShawnyB
Oct 23, 2009 11:53 AM
Ram
Oct 27, 2008 08:34 PM
workaholic2001
Oct 27, 2008 01:19 PM
