2001 Sbring Conv. Starter replacement
Old Nov 7, 2010 | 06:02 PM
2001Sebringconv's Avatar
Default 2001 Sbring Conv. Starter replacement
Thanks in advance for any help you can provide.
I need to replace the starter which appears to be located behind the front engine mount. Looks like you need to remove the engine mount from the block, is that correct or is there a easier way?
Thanks,
Gary
Old Nov 7, 2010 | 09:17 PM
Which engine?
Old Nov 8, 2010 | 06:28 AM
Sorry I should have mentioned that. 2.7 V6
Gary
Old Nov 8, 2010 | 10:16 AM
You need to remove the front downstream oxygen sensor, then remove the engine mount through-bolt. Then remove the engine mount bracket from the engine block.
Remove the battery cable from the starter and remove the lower starter bolt and the starter should come out.
aifam55
Jan 22, 2011 05:49 PM
mikemonce
Mar 5, 2010 05:12 PM
aqualungtj1
Sep 11, 2009 08:48 AM
Floyd Newport
Jun 19, 2007 09:19 AM
