2001 Sebr Convt: New rear caliper, new pads, still brake overheat. Help?
Old Jun 25, 2012 | 12:37 PM
CarComp's Avatar
Default 2001 Sebr Convt: New rear caliper, new pads, still brake overheat. Help?
I have a 2001 Sebring Convertible Limited. Its a fine car. The only issue I've had with it is that the passenger side rear brake doesn't want to release on its own sometimes. You can pry on it with a screwdriver through the wheel and easily it compresses, but if you drive a long way, you will stop and the brake will be smoking.
The other side is ok. I replaced the caliper (have done so on many vehicles, so I know its right). The results are the same. Smoking brakes.
Does anyone know of a common issue with this problem, or has any suggestion where I search next?
I'm going to look for a pinched line, but honestly i'm not too hopeful for this resolution!
Thanks guys!
Old Jun 25, 2012 | 10:54 PM
trash in the line also the runner part may come apart on the inside
Old Jun 26, 2012 | 09:18 AM
Had the same problem on my 1995 minivan. Turned out to be a bad brake hose.
Another possibility. If yours does not have ABS, then it might be a problem with the proportioning valve. As Tech says, "trash in the lines" can cause problems there.
mrgrisanti
Oct 9, 2016 01:48 PM
imtattoo80
Jul 16, 2015 01:36 PM
chrysleroh
Apr 18, 2014 03:57 PM
300winchester
Oct 25, 2013 03:57 PM
jfyfe
9
Jun 25, 2011 09:20 PM
