2008 T and C rear caliper/e- brake cable
Old Apr 16, 2014 | 12:36 PM
chrysleroh's Avatar
Default 2008 T and C rear caliper/e- brake cable
I am having an issue where my left rear caliper is seizing-up. I had a similar problem with my right front, ended up replacing the caliper and rotor.
I would like to switch out the left rear caliper, but I notice the e-brake system is integrated with the caliper. My question is, how difficult is it to remove/replace the e-brake cable and does any one have any detailed instructions to do so?
Thanks!
Old Apr 16, 2014 | 03:28 PM
Sounds more like a Calipher renewal required due to internal seals sticking.
Old Apr 16, 2014 | 04:40 PM
sundowners's Avatar
Hi
It might be worth taking out the caliper mounting bolts and cleaning them and refitting them with a little lube. (I have just had mine apart and the 'shiny' part was covered in sticky rubber crap----I wire brushed them and refitted with silicone grease)--------I bought new pistons for the calipers but they are releasing just fine now so they will stay in their box until I have to strip the brakes down again (or they start binding again.)
Nigel
Old Apr 17, 2014 | 07:40 AM
chrysleroh's Avatar
Thanks- when you say "caliper renewel" are you referring to a re-build? I typically replace calipers rather than rebuild (little more expensive but less time for me). When you do a renewel or rebuild do you still need to completely remove the caliper (and parking brake cable)?
Old Apr 17, 2014 | 03:47 PM
Easier to rebuild with Caliper off. Problem is getting right piston and seals as Chrysler will want to sell you a rebuilt unit. A Motorfactor can get you rebuilt units, usually part exchange. Use the red brake grease on rebuild. Might get pistons & seals on Flee-bay..
Way back in 70's you could buy Caliper and cylinder repair kits complete with pistons, seals, nipples and outer dust seals...Long Gone...
Old Apr 18, 2014 | 09:42 AM
chrysleroh's Avatar
Thanks all, but that leads me to my original question, how do I remove and replace the parking brake cable from the caliper?
Old Apr 18, 2014 | 03:57 PM
I take it you've not got inside disc brake shoes like mine, so is it electric handbrake ?
imtattoo80
Jul 16, 2015 01:36 PM
300winchester
Oct 25, 2013 03:57 PM
CarComp
Jun 26, 2012 09:18 AM
jlampitt
May 21, 2012 11:05 PM
Canytra
Mar 30, 2012 01:00 AM
