2001 Sebring Driver Side Mirror Replacement
My wife recently trashed the drivers side mirror on the door pillar of our garage while backing up.
I have a replacement unit that I picked up off ebay. How do I get the old one off? Is is a matter of just pulling off that plastic piece at the other side of the mirror inside the car?
I would really appreciate any help that anyone has to offer on how to do this.
if youve got the coupe, you pull off the tweeter/ plastic cover and there will be i think 3 nuts. loosen those, pull the mirror away and do the opposite to put the new one on. hopefully i got it right.
Thanks a lot — To answer you question, I have the sedan. Will the removal of that plastic piece still apply? Do you lever it off with a flat blade scredriver or something?
REMOVAL [ol][*]Remove side view mirror cover (Side View Mirror Cover).[*]Remove the door trim panel (Refer to 23 - BODY/DOOR - FRONT/TRIM PANEL - REMOVAL) .[*]Disconnect power window mirror motor wire connector, if so equipped.[*]Disengage wire harness grommet from mirror flag, if so equipped.[*]Disconnect manual mirror adjuster from side mirror cover, if so equipped.[*]Remove nuts attaching side view mirror to mirror flag (Side View Mirror).[*]Remove side view mirror from vehicle.[/ol]
Door trim Panel
[ol][*]Open door.[*]Lower window.[*]Disconnect battery[*]Open the screw cap from bottom of arm rest pull cup and inside remote handle.[*]Remove screws attaching door trim panel to door.(Front Door Trim Panel)[*]Remove screw attaching door latch handle to door panel.[*]Using trim tool, disengage clips holding trim panel to perimeter of door.[*]Lift trim panel upward to disengage upper retainer channel.[*]Tilt top of trim panel away from door.[*]Disengage clip holding latch linkage to back of release handle (Linkage Clip).[*]Disconnect main wiring harness at door opening.[*]Remove door trim panel from vehicle. [/ol]
Door trim Panel
You are a genius Chrysler Tech! I had the job done in 20 mins.
Exactly as you explained.
Of course I told my wife that I spent all Saturday working on it while she was out shopping with my daughters!
Do you think that she will believe me?
THANKS AGAIN!
THANKS AGAIN!
J Wikoff
Mar 29, 2012 03:38 PM
killerz298
Jul 25, 2011 12:45 AM
thudpucker
Aug 28, 2007 07:36 PM
