2001 Sebring radio and alarm not working.
I just recently purchased an 01 Sebring, four door, sedan and the radio obviously has power to it because there are three little lights on the controls that are blinking, but other than that there seems to be no sign of life. Also, the alarm seems to be disabled or something because when I lock the door, reach in though the window, and pull up the lock, nothing happens (beside the door coming unlocked). When I got the car, there was no keyless entry pad, but I called a dealership and they looked up my VIN number. They said that it is equipped with a key-less entry. I take that as my car should have an alarm. Am I right? Another thing that leads me to believe the alarm is disabled is that i attempted to purchase a keypad and when they went to sink it, it wouldn't sink.
Now, I changed all the fuses... So, I don't think either of my problems with the radio issue. Is there a fuse that is connected to the alarm? If so, where is that located? My question is, could these two be related? Maybe they share a wire? Could I possibly replace that myself? I have read that on my particular make/model/year car, that when the battery is disconnected and reconnected it disables the radio (if that's true, could it have disabled the alarm?)... leaving only these lights flashing. If this is true, how do I reset it? It's not asking for a code at all, like I said there is no sign of life but those three little lights blinking. Please help? This is driving me nuts. I hope I have supplied sufficient information. Thanks in advance, Julia.
Any other oddities, like the power seat not working?
I would suspect the IOD fuse, it's the center one with the "ears" in the fuse panel at the end of the instrument panel. IOD stands for ignition off draw, and supplies current to things that need it even though the key is off, like the clock in the radio and the remote keyless entry.
If replacing that fuse doesn't solve your radio problem then there's a good chance the radio is shot. It happens.
Thank you so much for replying. I don't have power seats, but everything else in the car is working splendidly. Only thing not working is the radio and alarm. Sadly, I have already replaced that fuse. =/ Guess I will be getting a new radio.
Gma891135
Dec 1, 2014 09:21 PM
DaveK
Jan 16, 2014 08:16 PM
Bassman85
Feb 23, 2011 04:12 PM
azev314
May 28, 2008 01:55 PM
bradybun
Oct 13, 2005 07:18 PM
