2002 convertible interior door handle
Old 06-12-2022, 12:32 PM
jray44's Avatar
Default 2002 convertible interior door handle
Does anyone know of a source for a replacement driver's side door handle that will fit my 02 Sebring Convertible Limited? Can't seem to find one anywhere for the convertible.
Old 06-12-2022, 04:30 PM
Given the age of the car, a junkyard handle is probably your only hope. The handle would be the same from 2001 through 2006. If I am not mistaken, it may be the same handle as far back as 1996. A sedan handle might work, the coupe handle will not (coupes were built by Mitsubishi and almost nothing will fit.) You can also look on eBay. While the handle itself may not be listed, you may find somebody who is parting out a car and has listed some other part(s). Write to him and ask if the handle is available. I have found parts that way. They built a lot of those convertibles so there's a good chance you'll find something. Junkyard parts can be found on the internet. Good luck.
Old 06-17-2022, 06:12 PM
jray44's Avatar
Thumbs up
As you suggested, I ordered a sedan handle but found it the bezel was too small but handle was the same. I removed the broken handle by pulling out the pin holding the spring and handle to the housing and replace it with the new one. Works like new and at less than $25. Thanks for your suggestion.
miahg17
07-29-2013 05:56 PM
SpoodyJ
07-19-2012 09:41 PM
jimG
10-21-2010 08:19 PM
jimmyjets33
05-11-2008 08:42 PM
Knaackers
04-08-2007 05:29 PM
Quick Reply: 2002 convertible interior door handle
