2002 power window problems
Old Mar 2, 2009 | 02:06 PM
pauliwalnutz's Avatar
Default 2002 power window problems
The passenger and 2 back power windows will only work when using the driver's controls. The lights are on in the individual switches. Some kind of relay in the driver's door?
Old Mar 2, 2009 | 09:00 PM
Thre's a "Lock" switch at the driver's door that locks out the other switches to keep the kids from fooling around with the windows. I'm assuming you are familiar with the proper operation of that switch. It could have gone bad and need replacing.
Old Mar 3, 2009 | 07:33 AM
Thanks. I've played around with the switch but still the same problem.
Old Mar 3, 2009 | 01:44 PM
Then the most likely source of the problem is that lock switch. It's an integral part of the whole switch there, not a separate component. There is no relay in the circuit after that switch.
Joey-D
Jan 6, 2019 12:34 AM
07pacificaNH
Mar 8, 2013 08:08 PM
ronsemko
14
Nov 10, 2010 07:00 PM
LT102
Jan 27, 2008 06:45 PM
wmcleod
Feb 1, 2006 10:30 PM
