2002 Sebring - Transmission "pauses" when going in gear
Old Mar 20, 2009 | 09:24 PM
davereed's Avatar
Default 2002 Sebring - Transmission "pauses" when going in gear
Good Evening All,
My wife told me the other day that her car has been "slow" to go into gear when she puts it in gear, going out of park into drive, from drive into reverse, etc. That she shifts the gear, but that it seems that the car is in "neutral" for a few seconds before it "recognizes" that she has changed gears, or that sometimes it doesn't recognize it until she tapes the gas, when it seems to "lurch" a little bit into gear, then is okay.
She then told me today that when she is going down the road, when braking somewhat hard (meaning, stopping at a light from 40-55 or so), it seems to "jar" a little bit when slowing down, though she doesn't change gears.
I took it for a test ride tonight, and noticed the things she describes.
Does anyone have any indication/suspicions about what the problem might be? At first I just attributed it to the colder winter weather here in Central Maine, but, it's warming up now, and it's not better.
Thoughts?
-David
Old Mar 21, 2009 | 03:16 PM
davereed's Avatar
Default Follow-Up...
Hi all,
Based on some of the things I'd read here last night, when I took the car in for an oil change today, I had the automatic transmission fluid replaced too, kinda hoping that it might be air in the line, and since the vehicle is now 97,300 miles, it seemed due.
So after they replaced the transmission fluid, I took it out for another test ride. It actually seemed that the "studdering" problem of downshifting when braking had gone away for about 10-15 minutes, but then it returned. We haven't experienced the problem of it going into gear when first coming/going in the morning (that seems to have gone away with the warmer weather, after discussing it with my wife this morning), but even after replacing the transmission fluid in the car, it was fine for about 10-15 minutes, and then the problem seemed to return, as bad as before.
So I'm not sure what to think...anyone got any ideas?
-David
Old Mar 21, 2009 | 10:14 PM
dusty-schaffner's Avatar
check fluid level, or this might be a future sighn of tranny failure, this happened on our jeep and the fluid happened to be low, ruined the whole tranny. happened on our minivan, tranny exploded......
Old Mar 21, 2009 | 10:17 PM
davereed's Avatar
Default Transmission Fluid change
I had the transmission fluid changed today, emptied and completely replaced. Shouldn't be any problem with that...
Thank-you!
-David
Old Jul 26, 2013 | 07:35 PM
Vitte's Avatar
They re=engineered the transmission solenoid. Runs smooth, gearing is smooth and pick up is faster without any pause. Check into it! They will not tell you.
Old Jul 27, 2013 | 08:56 PM
Thundercraft's Avatar
never mind... didn't realize that this was an old thread brought back to life....
Last edited by Thundercraft; Jul 27, 2013 at 08:58 PM. Reason: answer was not relevant to an old thread
HowieF16
Oct 13, 2014 03:49 PM
teddysmith1952
Dec 8, 2012 11:17 AM
teddysmith1952
Dec 10, 2011 09:15 AM
JeriKu
Jun 24, 2011 10:34 PM
davereed
Mar 24, 2009 04:45 PM
