2003 Sebring Front End Thunks
Old Jul 6, 2017 | 09:27 PM
marcusmerritt's Avatar
Default 2003 Sebring Front End Thunks
2003 Sebring sedan; 2.7 engine; automatic; 135K miles...I've had squeaks and creaks and thunks from my front end and have replaced the following on both sides: Strut towers; upper and lower control arms; stabilizer bar links; stabilizer bar bushings. That solved many noise and wear problems but I still have a thunk when braking (usually at slow speeds) and sometimes when accelerating from a stop. Also intermittently when turning. What's making that thunk?? Thanks for any input.
Old Jul 7, 2017 | 10:56 AM
Could be tie rod ends, inner or outer. Get the car up on a hoist or jackstands and see if you can reproduce the sound either by arm-wrestling the tire or actually applying power and braking. You might need an assistant to help with the observations.
Old Jul 7, 2017 | 11:49 AM
jopizz's Avatar
Also check your motor mounts.
John
Old Aug 21, 2017 | 06:47 AM
marineengineer's Avatar
Possible CV Joint issue? I had this problem on a older Chevy Cavalier.
procraneop
Aug 7, 2014 07:55 PM
goggs
Jun 14, 2013 03:04 PM
fletch5727
May 13, 2012 07:36 PM
Lucutious
Jan 8, 2012 01:24 PM
lwkoss
Mar 3, 2008 06:10 PM
