2003 Sebring Sedan thermal sensor
Old Apr 12, 2011 | 01:06 PM
2003sebring's Avatar
Default 2003 Sebring Sedan thermal sensor
I have a 2003 sebring LX sedan 2.4L. My thermal guage in the dash never goes over the first two notches. The guage itself works since I have done the test to see what all works in the dash.
How hard is it to replace the sensor and is is ok to put off the replacement?
I drive 42 miles at a time so the engine does get up to operating temp.
Old Apr 12, 2011 | 02:13 PM
My 2001 and my 2002 both do the same thing. If you are getting good heat out of the heater in the winter, the car is probably warming up fine.
Old Apr 12, 2011 | 02:15 PM
more then likely broken thermostat
Old Apr 14, 2011 | 12:29 PM
Where is the thermostat located and how hard is it to replace?
Are there any ill effects from putting off the repair?
Old Apr 14, 2011 | 09:18 PM
fallow the heater hoses
Old Apr 15, 2011 | 08:24 AM
The thermostat housing is right below the radiator cap on the 2.4L engine.
"Ill effects of putting off the repair": Slightly worse gas mileage, cold toes waiting for the engine to heat up.
Once you get the thermostat out you can test it in a pot of hot water on the stove.
2003sebring
Mar 23, 2011 07:55 PM
2003sebring
Feb 21, 2011 03:29 PM
johnjofus
May 27, 2009 11:05 PM
Jimbo034
Feb 5, 2009 10:05 PM
