2004 2.4L crankshaft/cam position sensors
Old Dec 11, 2013 | 12:52 PM
17FiXxXeR75's Avatar
Default 2004 2.4L crankshaft/cam position sensors
My roommates's car suddenly had a no-start condition. She has a 2004 Sebring 4D Sedan with a 2.4L DOHC X VIN EDZ engine. She had DTC indicating crankshaft position sensor and camshaft position sensor trouble.
Camshaft position sensor was easy enough, but the crankshaft position sensor seems to be a pain. I think I've finally located it wedged between the starter and the bumper-to-crossmember bracket. The wires are the right colors and the back of the connector appears to be correct, although I can't see the sensor itself.
Does anyone have directions on how to removed the sensor? It appears I'll have to remove the starter to access the sensor and its connector.
Any help would be greatly appreciated.
Thank you.
Old Dec 11, 2013 | 03:25 PM
I can't find a means to edit the post, but I wanted to list the DTC I found:
P0340 and P0016
Old Dec 11, 2013 | 11:05 PM
is the timing belt broke?
Old Dec 12, 2013 | 08:54 AM
That's the next thing I'll check.
I finally got to the cam position sensor after disconnecting the starter. I replaced the sensor but it's still throwing the same code.
She said her engine made some sort of weird noise, but she can't describe either the noise or from what part of the engine it came from. It could quite possibly be her timing belt.
That means it's time to take it to a shop.
Thank you.
idabomb00
Jul 25, 2015 06:09 PM
Gypsy
Jun 29, 2011 01:50 PM
BACdaG1
Nov 10, 2010 09:35 AM
96RedLXI
Jul 19, 2008 08:38 AM
