2004 Sebring Traction Control?
Old Mar 26, 2020 | 06:17 PM
Leo Psaroudis's Avatar
this is a picture of my steering column i dont have trac control but if i did the button would be right there
Old Dec 16, 2020 | 05:10 PM
gpatel's Avatar
Default How to switch off traction control
How to switch off traction control?
you already got the answer, there is a button/push down switch on steering column behind steering wheel. This is used to turn on/off TC. It turns ON each time you start car.
i have this in 2.7L 2006 Sebring Touring.
Old May 31, 2021 | 04:27 PM
toyota's Avatar
Default Traction control 2006 Sebring 2.7L
Originally Posted by greeniebfd
I have a 2004 Sebring touring it has a button on the top of the steering column to turn off the traction control then there is a light in the dash like a car skidding that stays on but each time you start the car it goes back to traction control. Also when mine is in traction control and the wheels start slipping and it is engaged it sounds really bad like the rotor are grinding against metal took to dealer but they have no idea what it. Is this comm. Any one else that has traction control here this type of noise on theirs….Thanks
Traction control on my 2006 is perfect in that it does not make any noises when switch button on top of steering wheel is pressed on or off. Check and spray WD40 on wheel sensors and make sure ring gear teeth on the abs are clean.
Old May 31, 2021 | 04:31 PM
toyota's Avatar
Originally Posted by gpatel
Hi, Do you know how to switch off traction control on 2006 Sebring Touring?
thanks
traction control switch is next the HAZARD light switch on the steering column. Its a push down button.
Old May 31, 2021 | 08:51 PM
  #15
When all else fails, RTFM. You can get an owners manual for model years 2005 and up at chrysler.com.
billbon8
Aug 5, 2022 12:25 PM
ranzy
Jul 12, 2015 11:15 AM
Hamilton
Mar 11, 2009 04:55 AM
tcoxcsr
Jun 23, 2008 08:07 PM
F150
Mar 15, 2007 12:13 AM
