2004 sebring will not start/battery charged
Old Jul 6, 2009 | 03:36 PM
TWH's Avatar
TWH
Default 2004 sebring will not start/battery charged
car was parked and 1 hour later would not start any thoughts?
Old Jul 6, 2009 | 09:01 PM
Could be that the battery is shot and won't hold a charge at all. Could be corroded terminals in the starting circuit won't allow starting current to pass. Could be a blown starter motor. Could be many things. Have you checked for codes? Does it crank but not start? Does it click but not crank? Do other things work, lights, horn, etc?
Old Jul 7, 2009 | 03:32 PM
TWH's Avatar
TWH
Thanks for your input following is an update. New battery (old one would not maintain a charge), replaced starter relay-- results nothing changed. Horn works, lights work,top works, does not even attempt to crank. Acting as if the circuit is wide open ?
Old Jul 7, 2009 | 10:57 PM
KYBarrister's Avatar
Check all the fuses in car and engine compartment?
Old Jul 8, 2009 | 02:28 PM
Check the key switch and the neutral safety switch. Try wiggling the shift lever as you turn the key.
amk64
Jun 14, 2015 02:09 AM
kimybrown
Nov 22, 2014 05:35 AM
La_TomboyGirl
Mar 11, 2012 08:04 PM
msg123456
Jan 24, 2011 10:20 PM
jaredfield
Jul 15, 2010 03:25 PM
