2005 Chyrsler Sebring Horn/Alarm
Old Oct 31, 2007 | 09:24 AM
missangeladjones's Avatar
Default 2005 Chyrsler Sebring Horn/Alarm
While driving this horn/alarm goes off by itself...can some one help me with that one
Old Oct 31, 2007 | 02:35 PM
YZF600RN's Avatar
Default RE: 2005 Chyrsler Sebring Horn/Alarm
Hello MissJones,
I am new to this forum but I just had a similar problem with my 06 sebring. I do not have an alarm on my car. Just the regular remote for door locks.
The dealer had to replace the whole airbag assembly in the steering wheel.
It was the horn pad that was bad and sticking and in the process activating the horn. I believe the horn pad is attached to the airbag or can only be ordered when buying a new airbag.
It just started on mine about two weeks ago. The car horn will go off randomly while I am driving or when the car is parked at night. I am not sure if it was weather related since it started to get cooler at nights here.
Anyway, my car was under warranty so they fixed it.
Hopefully yours is too.
I hope this helps.
Old Oct 31, 2007 | 07:27 PM
truck tech's Avatar
Hello,YZF600RN is on the right trail.This happens in temp. changes or when there is a lot of moisture. Thespace between the contacts is very close and moisture can make the conection causing the horn to go off, either way you need to get to the dealer and have them check it. Chrysler Tech or Moe may be able to share some light on the subject. May be a TBS out on this matter. Good Luck and God Bless!!
Old Nov 2, 2007 | 11:19 AM
Thank you very much i took my car back to chrysler and they had to change the horn pad assembly and air bag. Thank you so much for the advice. My car is fixed and i appreciate the help from u guys.
CarlEatshands
Sep 24, 2013 10:04 AM
cproc501
Apr 1, 2011 09:49 AM
grandvoyager1
Jun 14, 2008 12:06 PM
rcubedor
Feb 10, 2008 05:51 PM
2004LX
Sep 1, 2005 11:31 PM
