2006 chrysler sebring 2.4 engine sedan coolant problems
Old Jun 26, 2011 | 03:19 PM
Diana741100's Avatar
Default chrysler 2006 sebring
Guys! What type of anti freeze coolant do i use?
Old Jun 26, 2011 | 03:27 PM
Neither you nor I have any idea how much antifreeze you have in there. If it's been boiling out and first you added water in an unknown quantity, and then you added 50-50 antifreeze in an unknown quantity, the only thing that can be stated for certain is that the amount of antifreeze you have in there is not correct.
You need to have about 4 and a half quarts of 100% antifreeze in there. The rest needs to be clean water. Alternatively, completely drain the system and pour in about 9 quarts of 50-50 antifreeze. Completely draining the system is not an easy job.
Have you replaced the pressure cap as suggested?
Old Jun 26, 2011 | 03:32 PM
Look for 100,000 mile five-year anti-freeze. You shouldn't mix colors. There are green, orange and gold colored antifreezes on the market. By now, you probably have no idea what was in there before. Best thing to do is get the system fully flushed and properly refilled.
Old Jun 26, 2011 | 03:36 PM
Thank you Sir for your expert advice.. After i put the antifreze and have it flushed and installed with coolant.. Will the engine light dissapear?
Old Jun 26, 2011 | 07:46 PM
  #15
possible broken thermostat
Old Jun 26, 2011 | 08:44 PM
  #16
Sir, Just changed my thermostat.. Could there be a leak somewhere?
Old Jun 26, 2011 | 11:36 PM
  #17
no one online can tell u where your leak is if U have one
Old Jun 27, 2011 | 08:53 AM
  #18
When you go in for the system flush, have them run a pressure check. They will pressurize the system and see if it holds. If it doesn't hold pressure, there's a leak somewhere. With luck, they'll be able to spot it. Like Tech says, you can't do that over the internet.
Old Sep 10, 2011 | 11:19 PM
  #19
sebringshell's Avatar
I went and got oil changed and asked them to test coolant they drained off some added more and Voila no code ... had to pay for antifreeze but at least i know its testing for normal.
CarlEatshands
Sep 24, 2013 10:04 AM
Jplay909
Mar 17, 2011 10:00 PM
deb963
Dec 10, 2007 10:30 PM
deb963
Nov 11, 2007 08:02 PM
