2006 Sebring convertible 2.7 No Crank.
Old Jan 11, 2021 | 09:14 AM
kcagle57's Avatar
Default 2006 Sebring convertible 2.7 No Crank.
Dash lights go off when key is turned to start position. The first thing I checked was the 20A yellow fuse was ok, I jumped out contacts on start relay and starter cranks,I swapped the relay with a good one still nothing. It is not getting power to coil side of starter relay I checked the shift cable to make sure park was engaged . I replaced the ignition switch, still no start. The only thing I can think of is the PCM or the TCM. Next stop is tow to shop unless one of you fine mechanics can figure it out. Thanks.
Old Jan 12, 2021 | 10:21 AM
Get a code reader on it and check for codes. Eliminate all the cheap stuff before you decide to start replacing expensive things like computers. What is the state of the battery? Are all the battery connections and grounds clean?
Old Jan 12, 2021 | 04:32 PM
kcagle57's Avatar
I did all that. I took it to an auto repair shop today, but thanks anyway.
Old Jan 16, 2021 | 06:39 AM
Marcelvg's Avatar
i think battery low
jetman750
Mar 10, 2017 01:04 PM
kwkride
Oct 25, 2016 10:31 AM
2001sebring2point7
May 9, 2015 12:22 AM
mlo356
Jan 13, 2013 03:21 PM
p8ntballnxj
Feb 5, 2012 07:23 PM
