2007 sebring 2.7l trans code p0765
Old May 29, 2013 | 06:48 AM
AKADIEN's Avatar
Default 2007 sebring 2.7l trans code p0765
I have a chrysler sebring 07 with a 2.7l and 41te transmission, i have code p0765 ud solenoid circuit , check and the solenoide pack and resistance for the four solenoid is 1.7 ohms and the pressure switch 300 ohms, so i take the wirring out and check it find nothing bad with it , so after that decide to change the solenoid pack on it , same problem , on the scanner my temp for the transmission stay at -19.4 , so with the scanner on a unplug the transmission range sensor that the temps sensor is in it and no change still -19.4 , after that i decide to go a the junk yard and buy a use pcm , put the pcm it in got the same problem nothing change , do some buddy have and idea what is the problem????
Fhorlando
Dec 22, 2014 01:10 PM
mkz1
Sep 2, 2013 02:30 PM
parlayjay
Apr 18, 2010 03:28 AM
goestens
Mar 12, 2008 10:47 PM
benr
Feb 25, 2007 03:44 PM
