2007 Sebring P0302 help
Old Mar 25, 2015 | 04:39 PM
marauder3971's Avatar
Question 2007 Sebring P0302 help
I am having an issue with my 07 Sebring. it's the 2.4L, throwing a P0302 code. ( cylinder 2 misfire). The problem started to come and go, now it just stays. The spark plugs have been changed twice, the coil has been changed and the fuel injector has been changed. Other checks turn up no results that show a problem.
compression test and voltage/ohm checks for wiring to plugs and injectors.
I took it to a mechanic and he blamed the spark plugs, saying they were incorrectly gapped. Car manual says .040. He found them at .035. They were adjusted and replaced a couple days later. The CEL stayed and I just checked them again, 3 weeks later, they had expanded to .055, again returned to specs for car. It's causing light, bad gas mileage, rough idle, poor performance ( not that it has alot anyway )
I searched but turned up no results, if this topic is on here then could someone provide a link.
Has anyone else had a problem like this? What were fixes?
Old Mar 26, 2015 | 07:24 AM
metalman3's Avatar
had the some problem after i had replaced all the pencil coils. ended up that one of the new coils was bad. replaced it with one of the old ones and ran just fine. reset the ck eng light and all is well.
Old Mar 27, 2015 | 08:26 PM
I moved two of the coils to see if the problem followed and it did not. Replaced the coil on that cylinder for good measure. Nothing changed. I don't have the capabilities to do much more myself and am wondering if its internal. i was hoping that someone had a similar problem for some insight and to avoid a shop trip. thanks for the response though.
Embowe
Mar 12, 2011 08:57 AM
kushn
Aug 12, 2010 10:54 AM
runtime
Jun 11, 2010 08:06 PM
JeepInfoCenter
Nov 8, 2006 10:41 AM
