2007 Sebring won't start
I have a 2007 Sebring when you turn the key nothing happens all the interior lights work, the car has power to everything else , there's no sound when turning the key it's like the battery is dead but everything still has power
I had similar problem with my 2001 Sebring. Replaced the engine computer and that didn’t work. Found out the BCM needs resetting. Simply put your key in the door lock. Turn key towards front of car then back to straight up and down then towards front of car and back to straight up and down. The BCM is now reset and my Sebring started and been running fine since. Hopes this helps.
So my 2008 had the same thing happen. I have a 2008 Chrysler limited hardtop. I parked the car at a store and when I came out the trunk wouldn't pop. I could lock and unlock the doors with the fob. But I couldn't raise or lower the top or pop the trunk with the fob or internal buttons on the dash. We tested the battery and it was getting 12 volts. We tried bypassing the starter but it still wouldn't start. The radio, a/c, interior dash all works fine. I had to get it towed to a dealership to get a diagnostics done. It will be a few days before they get to it.
READ post #4, Not just volts are needed, cranking amp are part of electrical operation. That is why batteries carry a CA/CCA rating on them. A battery load tester is required for this quick and easy check. AND if your battery is more than 4 years old, it is probably on it's last "legs".
So my issue was the shift cable bushing. The video to replace it can be found here
As a side note... In checking to make sure that the cable was fine and that I was only missing the bushing I removed the console. We started by unhooking the battery. After putting everything back in place and the car would start I have a few issues that I didn't have before.
After I start the car the brake, ABS, ESP BAS, and Engine lights come on and stay on and the speedometer doesn't work. Ive tried resetting the speedometer by holding down the trip button as I start the car but that doesn't fix the issue. It also doesn't warn me that my seatbelts are not buckled. Everything else appears to work fine. Error Codes were U1110 and U1120. Ive tried clearing the codes and the U1120 went away but the U1110 is still there.
To answer the question its a 3.5 V6
DanNotTheMan
Sep 17, 2012 01:36 PM
