2008 Sebring Instrument cluster removal
Old Jul 1, 2015 | 03:52 PM
TonyW's Avatar
Default 2008 Sebring Instrument cluster removal
I need to replace my Dash (Instrument Panel) and was wondering if there is a link or information on how to remove the dash. I do not want to start taking it apart without some knowledge of what I need to do first etc.
I would appreciate and help and wisdom.
Old Jul 1, 2015 | 06:43 PM
Old Jul 2, 2015 | 05:14 PM
TonyW's Avatar
Thank you for the info However, the removal info was for 2005 to 2007 which has a different dash
Old Jul 2, 2015 | 07:45 PM
They answer questions there. Chances are they'll have some information you can use. The 2007 should be the same as the 2008. The big change was in 2007. 2008 was not much different.
Old Apr 27, 2018 | 07:18 PM
kodyoteymane's Avatar
Any repair tips or wisdom on when only the speedometer stops functioning but the rest of the gauges work?
Old Apr 27, 2018 | 09:09 PM
Is the transmission acting up? The output speed sensor provides the signal for the speedometer. Shifting would probably be erratic if the sensor has stopped working. If the shifting is good, then the problem is further down the line. Engine control module, body control module, wiring or the speedo itself.
Circle over to this website and hunt around there. The guy will answer your personal questions:
Speedometer Repair | Instrument Cluster Repair | Odometer Repair | Mr. Whizard
rollinsr99
Dec 3, 2014 02:33 PM
Si Preston
Aug 12, 2014 04:05 PM
crysler
Apr 30, 2013 08:13 PM
landispa
Mar 1, 2013 01:01 PM
2003sebring
Feb 25, 2011 09:00 PM
