2008 Sebring, no power
Old Jan 2, 2024 | 10:54 AM
Unameit's Avatar
Default 2008 Sebring, no power
No power anywhere, 2008 Chrysler sebring what could cause this? Was driving pulling in the driveway and car shut off, just as if you turned the key off. Now I have no power to everything.
Any help would be greatly appreciated!
A couple thoughts that I have is possibly ignition switch or TIPM.
Old Dec 17, 2024 | 02:46 PM
KlumzyAssMexican922's Avatar
Default Rene
take apart your tipm and check if it burnt out
Old Dec 17, 2024 | 04:24 PM
ggoose's Avatar
Does the battery show voltage at the jump points on the left side of the engine compartment? If not, check that both ends of the battery cables are corrosion-free and secure and check the battery directly for voltage. Voltage at the battery needs to be at least 12.2 volts.
Check the power cable to the bottom of the TIPM. There have been instances where the cable is no longer securely attached.
WesternReach1
Aug 10, 2019 10:09 PM
Deltron001
May 28, 2018 08:13 PM
ptarno
Nov 13, 2015 01:55 PM
DaveK
Jan 16, 2014 08:16 PM
