96 JXi 2.5L Oil Pan
Old Feb 13, 2014 | 12:33 PM
noasinc's Avatar
Default 96 JXi 2.5L Oil Pan
Need to replace an Oil Pan seal or gasket. It is leaking. Is it actually necessary to remove the engine support module to remove the oil pan. Some repair manuals mention that "it maybe necessary" .
Old Feb 14, 2014 | 07:56 PM
Not all Chryslers have one, but if you have one, it'll almost certainly be necessary to remove it to get the oil pan out. It's a fairly substantial piece that connects the front and rear engine mounts and passes directly under the engine. If you can figure out a way to get the pan out around it, come back and let everybody know. You might be able to disconnect one end and swing it down enough. Take some pix and report back.
Lisa C
Mar 21, 2008 09:37 AM
I wonder
Mar 1, 2008 08:35 AM
02sebringCT
Nov 22, 2007 12:39 PM
catliketheif6
Nov 20, 2007 11:27 PM
dennine3003
Feb 24, 2006 07:50 AM
