96 Sebring Convertible JXI Auto Shutdown Relay Fuse
Old Mar 18, 2012 | 05:37 PM
Ms.Scarlet's Avatar
Post 96 Sebring Convertible JXI Auto Shutdown Relay Fuse
Hello,
I have a 96 Sebring Convertible JXI 2.5L V6. Once my car has warmed up and I push down full throttle on the gas I blow my auto shutdown relay fuse (ASD). We have replaced the actual relay, the ignition coil inside the distributor, we have checked the computer for codes and nothing comes up, and we have checked the fuel injectors for open wires and we have not found anything. The car runs great. You can barely even tell its running. It starts up perfectly fine, and a complete tune up has been done(cap, rotor, wires, and spark plugs). Any suggestions as to what is wrong with my car?
Thanks for any help you can give me.
Old Mar 18, 2012 | 07:59 PM
a wire that is powered by the asd relay is shorting out when u give it WOT get a wire diagram and start tracing all the items that the ASD provides power to or that fuse is on.
Old Mar 20, 2012 | 02:44 PM
Ms.Scarlet's Avatar
UPDATE: We have traced all of the wires and checked all of the ohs. Everything checked out perfectly fine. There are absolutely no problems with the wires.
Old Apr 6, 2012 | 09:12 AM
Ms.Scarlet's Avatar
UPDATE: We have unplugged the O2 sensor to make sure it wasn't that and it was still shutting down. We then replaced the fuel pump and the car is still shutting down. Taking it to the dealership today to see what they have to say.
Old Apr 6, 2012 | 04:31 PM
Ms.Scarlet's Avatar
UPDATE: We have also replaced the PCM. Nothing has changed.
Old Apr 6, 2012 | 06:34 PM
TNtech's Avatar
Originally Posted by Ms.Scarlet
Hello,
Is this while moving or sitting still? ONLY warm engine or any temp? Alternator can also cause your problems.
Old Apr 7, 2012 | 07:39 AM
Ms.Scarlet's Avatar
This is while moving. Sometimes I can pop the fuse while in the bay without moving but its rare. It also happens at any temp.
Old Apr 7, 2012 | 07:46 AM
Ms.Scarlet's Avatar
We checked the alternator. It is charging 100%.
Old Apr 7, 2012 | 08:40 AM
TNtech's Avatar
It sounds like a wire is shorting to ground when the engine is torqued (twisted). Try looking at places where the harness bends around something sharp or a corner. The charge rate of the alternator has no bearing on the matter. The ASD feeds the field coil and there could be a condition that pulls too much current when you ramp up the RPMs. You can unplug the 2 wire connector on it and go for a short drive OR it can be full fielded with the DRB 3.
Old Apr 13, 2012 | 11:03 AM
Ms.Scarlet's Avatar
UPDATE: Took the car to the dealership and they have no idea what is wrong. So much for them having all the right answers....
