96 Sebring lxi 2.5 No Spark
Old May 20, 2011 | 01:39 PM
Sparky0403's Avatar
Default 96 Sebring lxi 2.5 No Spark
For about 2 weeks the car would take a few times to start, then one day just stopped starting. Cranks fine, has power to everything, checked fuses, replaced distributor, cap & rotor and asd relay. still no spark at distributor. Tested wire coming into distr and am showing 0 volts coming thru. Looking at replacing the crankshaft sensor next but looking for ideas.
The car has 140k on it
replaced fuel pump and filter about 6 weeks ago
Fuel pump relay tested fine
Ran great until this. Never died or stalled while running.
Old May 20, 2011 | 02:17 PM
Codes?
Old May 20, 2011 | 08:17 PM
Sparky0403's Avatar
11 & 55. the car threw no codes at me so I used the key to see if there were any codes. Obviously code 11 will be thrown since there is no power going to the distributor.
Old May 20, 2011 | 10:00 PM
11: "Intermittent loss of crankshaft and/or camshaft position sensor signals to PCM."
If you have browsed the forum here you'll notice that on that engine, for some reason crankshaft and camshaft sensor failures seem to go hand in hand. Maybe it's time to check the crank sensor.
55: Just means that it has reported all the codes.
WillQRose
Oct 18, 2018 07:18 PM
austin
Cirrus & Breeze
Sep 16, 2012 09:09 PM
queengsc
Apr 17, 2012 03:26 PM
Plugngo
Feb 28, 2012 02:59 PM
Emersive Audio Video
Jul 3, 2005 08:33 PM
