99 2.5 water pump inlet tube
Old Feb 8, 2015 | 04:54 PM
RichyRich001's Avatar
Default 99 2.5 water pump inlet tube
99 2.5 water pump inlet tube is leaking. can I take just the drivers side items off to change it? (Including the intake of course) Or do I have to remove the water pump as well?
Old Feb 9, 2015 | 03:11 PM
No one knows the answer to this question? Somebody here has changed a inlet tube before. HELP!
Old Feb 8, 2018 | 08:27 PM
Chris Fenning's Avatar
Doing this repair right now.
In short, yes you can leave the water pump in. You have to take the Thermostat/Coolant filler housing. Just remember, if you are leaking out of the water pipe inlet on one side, chances are its bad on the ither side and may require the kind of attention that requires the water pump and timing assembly...
Ny repair started off as a simple timinfg belt replacement, and here I am.
Pacifica830
Jul 10, 2017 12:47 PM
dmbeale
15
Nov 24, 2010 06:26 PM
captain catfish
Oct 2, 2010 04:32 PM
chief
K-Cars
Jul 19, 2008 12:54 PM
chief
Jul 19, 2008 12:45 PM
